3CX Wallboard Data Reset
Tin Nwe Win
Gold Partner
Dear 3CX Support Team,
Now we are facing 3CX Wallboard data reset automatically after 1PM even though we did the configuration setting as below.
Could you please kindly let me know how should I configure for this setting?
Thank you very much for your support.
You will need to check the timezone of the PBX.
If it is a Windows machine you will also need to make sure its timezone is also properly set, as the PBX does not control the timezone settings of a Windows machine.
Reactions: NicholasP_3CX
ARKC
