You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
- Status
3cx webapp keypad is disabled while on a call. Installed the 3cx DesktopApp and it won't load. It just sits on a blank screen.
@Wencie Beltran,
Can you provide us with a bit more info? What version of the PBX are you running? (you can check this from Dashboard)
What OS (and version) are you using?
Are you using any desk phones or other devices?
- Status
