3cx web client time zone
3CX_M
Intermediate Cert.
Hi, is it possible to set the 3CX web client to follow the time zone of the server? The 3cx web client is showing the time zone of the local computer logging onto the 3cx. Also the wallboard is following the time of the local machine accessing the 3cx web client. Would like to be able to set the time zone or to follow the server time zone, any ideas?
Don't sure it can fix your problem but have you tried to set the wanted timezone in phone provisionning settings, replace global timezone by the one you want and test if this solve.
11009
Won't change anything. This is only for physical phones. 3CX app and webclient uses local timezone.
@3CX_M You can check if there's a settings in the webclient to select the timezone, but I doubt it.
That's an improvement to be made because it can be needed sometimes.
hughesdouglas
