Solved 3CX will not upgrade to v18
thames
Hi there Folks
I am having a problem trying to upgrade to the v18. Each time I try I almost instantaneously get another login prompt and when I go back in and look at the log I see:
Your 3CX Debian OS failed to update
3CX Phone System Management Console ID: 10012 02/01/2022 00:00:16
Am I logging back in too quickly or is there a problem?
All the best
Chris
You should get an email with a log showing the issue. Otherwise you can check the log from the MC manually, it's likely an unusual package / source list or locked apt.
I always recommend a reboot before starting the upgrade.
Hi there - I'm not getting an Email and the log from the Dashboard just shows the exact message above. Completely stumped... :(
Reboot - you mean a server reboot? We are using Google instances for our 3CX installs. OK - will go do that and I'll get back to you. Many thanks!
Ureka! Thanks, SweetAction - all done and dusted and instances rebooted and all immediately upgraded.
Cheers
Chris
Glad to see you managed to get this sorted!
I'll be closing this thread so please feel free to start a new one should you need anything else!
Bluebox Global
