Solved 3CX Windows Client Wallboard Showing N/A
aclarkson
Hi All, the webclient for the wallboard is working perfectly. However the 3CX windows client is displaying N/A on all counters except for the date and time and the customisable message.
We are using the Enterprise version.
Are you logging in to both clients with the same extension?
Hi John, Problem solved.
That extension was not a queue manager.
Glad it was resolved!
gmacinit
