3CX Windows softphone will crash
newavealex
Forum User
when I use 3CX Windows softphone, using traditional Chinese input method in the search place will cause the system to crash.
My 3CX Windows softphone version is 16.0.1.88
The 3CX desktop app is deprecating, id advise to move to the Chrome Extension as users on Chromebooks can use it as well. Try it with the Chrome extension and see if you have the same issue.
The 3CX desktop app is crashing. It keeps ringing, I can't answer and the program hangs. Generated several dumps
Windows 10.0.118363.720
There the logs
gmacinit
