3cxManagementConsole.log
saint_
Forum User
Hi all,
I have a TON of provisioning errors in the file 3cxManagementConsole.log.
Are those only warnings, or real errors ?
See attached file.
I would say that most likely they are all related to a common provisioning denominator - in that all the errors are un-related/random (3CX Phonebook, HTek, Yealink phonebook, Grandstream language etc) I presume you are not using all these.
Check the provisioning service - is it running as it should, are you getting any actual issues ?
Hello @saint_
As far as i can see these are all common messages. If you are not facing any issues i would not worry about them.
laranicole.lucus
