  • V20 Update 10 RC Learn more
3rd party DECT : Fortinet
luc83
I'm totally new to 3CX and I want to test it.
I already have a few phones I would like to use for my tests : one Fortinet DECT base FON-D71-B and 2 DECT phones Fortinet FON-D71-H
Actually Fortinet devices are the same as Yealink (rebadged I think)
I tried to register the DECT base in my free 3cx without success
The problem is I don't know if this is because of my lack of knowledge or because of the Fortinet devices
Is someone able to help ?
Thank you
Please note that no advice can be provided with untested supported devices.
Please use only the supported IP/DECT phones or 3CX Webclients and apps: https://www.3cx.com/sip-phones/
You have two options...attempt to provision using a template that you think may work (which it sounds like you have done), or manually provision. If the device does accept provisioning using a template, and has a GUI, you might be able to "tweak" the settings, then disable any future re-provisioning to prevent the changes made being over-written. This is still going to require an understanding of what the issue, preventing registration, is.
younis sadikot
