3rd Party Website Integration - Reformat Incoming or Outgoing Caller
ConveneIT
We're looking into integrating 3CX with a web-based Job Management software.
Natively, it integrates with RingCentral, but it's just a URL that opens with a wildcard using %callernumber%
The issue we're having is that the number has to display in the 44 UK format rather than starting with a 0.
I'm looking over the CID reformatting, but can't seem to figure this out.
I think that the source pattern needs to be +(0)(...)(.*) but I can't figure out the replace pattern.
Any advise would be appreciated.
You mean +44203 etc? Yes then use a voip provider that forwards calls with caller ID in e 164 format. T4COM for example.
Thanks Nick,
So just to confirm, this has to be done at the VOIP Provider level?
CBHMIA
