Solved 603 Decline with 3CX v18 RC and previous betas for internal calls
webstean
I've found that internal extensions don't work with v18 RC and a couple of beta before that. External calls work fine.
I'm getting 603 Decline on any internal call - I'm using SBC accross three sites, with a cloud hosted 3CX.
It the same for a native SIP client and 3CX iOS soft phone and Fanvil handsets.
3CX Activity Log:-
Code:
08/03/2021 10:46:46 AM - [CM502001]: Source info: From: <sip:667@FQDN>;tag=62d6e2fe7a4f1392; To: <sip:666@FQDN;transport=udp>
08/03/2021 10:46:46 AM - [CM503013]: Call(C:7): Incoming call rejected, caller is unknown; msg=Invite-IN Recv Req INVITE from 1.136.111.201:48081 tid=619b0f961a0d00ec Call-ID=e2beb1e22b696e1b: INVITE sip:666@FQDN;transport=udp SIP/2.0 Via: SIP/2.0/UDP 172.24.175.206:33385;branch=z9hG4bK619b0f961a0d00ec;rport=48081;received=1.136.111.201 Max-Forwards: 70 Contact: <sip:[email protected]:33385> To: <sip:666@FQDN;transport=udp> From: <sip:667@FQDN>;tag=62d6e2fe7a4f1392 Call-ID: e2beb1e22b696e1b CSeq: 16275 INVITE Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, NOTIFY, SUBSCRIBE, INFO, MESSAGE, REFER Content-Type: application/sdp Proxy-Authorization: Digest username="1Q0FM8Asa9",realm="3CXPhoneSystem",nonce="414d5359610891f523:6d8c98f001af782164dea04f9d1f3196",uri="sip:666@FQDN;transport=udp",response="6c4da98fbbcfea282f1d80978ce5a006",algorithm=MD5 Supported: gruu User-Agent: baresip v1.1.0 (x86_64/linux) Content-Length: 352 v=0 o=- 690483025 1542754858 IN IP4 172.24.175.206 s=- c=IN IP4 172.24.175.206 t=0 0 m=audio 12584 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=sendrecv a=label:1 a=rtcp-rsize a=ssrc:4190757915 cname:sip:667@FQDN a=minptime:20 a=ptime:20
08/03/2021 10:46:46 AM - Leg L:7.1[Unknown:] is terminated: Cause: BYE from PBX
08/03/2021 10:46:45 AM - [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification: Invite-UNK Recv Req INVITE from 1.136.111.201:48081 tid=29e508bb2136392f Call-ID=e2beb1e22b696e1b: INVITE sip:666@FQDN;transport=udp SIP/2.0 Via: SIP/2.0/UDP 172.24.175.206:33385;branch=z9hG4bK29e508bb2136392f;rport=48081;received=1.136.111.201 Max-Forwards: 70 Contact: <sip:[email protected]:33385> To: <sip:666@FQDN;transport=udp> From: <sip:667@FQDN>;tag=62d6e2fe7a4f1392 Call-ID: e2beb1e22b696e1b CSeq: 16274 INVITE Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, NOTIFY, SUBSCRIBE, INFO, MESSAGE, REFER Content-Type: application/sdp Supported: gruu User-Agent: baresip v1.1.0 (x86_64/linux) Content-Length: 352 v=0 o=- 690483025 1542754858 IN IP4 172.24.175.206 s=- c=IN IP4 172.24.175.206 t=0 0 m=audio 12584 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=sendrecv a=label:1 a=rtcp-rsize a=ssrc:4190757915 cname:sip:667@FQDN a=minptime:20 a=ptime:20
08/03/2021 10:46:43 AM - Currently active calls [none]
SIP Trace:-
Code:
667@FQDN: selected for request
call uri: sip:666@FQDN
ua: using best effort AF: af=AF_INET
call: connecting to 'sip:666@FQDN;transport=udp'..
call id: e2beb1e22b696e1b
UDP 172.24.175.206:33385 -> IP:PORT
Max-Forwards: 70
CSeq: 16274 INVITE
Allow: INVITE,ACK,BYE,CANCEL,OPTIONS,NOTIFY,SUBSCRIBE,INFO,MESSAGE,REFER
Supported: gruu
Content-Length: 352
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=label:1
a=rtcp-rsize
a=minptime:20
a=ptime:20
UDP IP:PORT -> 172.24.175.206:33385
SIP/2.0 407 Proxy Authentication Required
Proxy-Authenticate: Digest nonce="414d5359610891f523:6d8c98f001af782164dea04f9d1f3196",algorithm=MD5,realm="3CXPhoneSystem"
To: <sip:666@FQDN;transport=udp>;tag=42dfcd5e
CSeq: 16274 INVITE
Content-Length: 0
ACK sip:666@FQDN;transport=udp SIP/2.0
Max-Forwards: 70
CSeq: 16274 ACK
Content-Length: 0
Max-Forwards: 70
Proxy-Authorization: Digest username="1Q0FM8Asa9", realm="3CXPhoneSystem", nonce="414d5359610891f523:6d8c98f001af782164dea04f9d1f3196", uri="sip:666@FQDN;transport=udp", response="6c4da98fbbcfea282f1d80978ce5a006", algorithm=MD5
CSeq: 16275 INVITE
Supported: gruu
Content-Length: 352
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=label:1
a=rtcp-rsize
a=minptime:20
a=ptime:20
SIP/2.0 603 Decline
To: <sip:666@FQDN;transport=udp>;tag=8f0b2c2a
CSeq: 16275 INVITE
Warning: 499 vmcca87306dd.kw4km1relcxevmrqjkvutzlkgg.qx.internal.cloudapp.net "Caller is forbidden"
Content-Length: 0
Max-Forwards: 70
CSeq: 16275 ACK
Content-Length: 0
sip:666@FQDN;transport=udp: session closed: 603 Decline
Please try the following and let me know what happens:
1. Access the Management Console and navigate to "Settings >> Network".
2. Click on the FQDN tab.
3. Make sure that the "Local SIP Domain" field(2) contains the PBXs FQDN exactly as show in the "Fully Qualified Domain Name" field above(1)
4. Click on OK and check to see if the issue persists.
Reactions: webstean
Ok - Thanks - that fixes it.
Reactions: ChrisC_3CX
Great! Glad this got sorted!
Reactions: webstean
devo.it
