802.1x Yealink Provisioning not working
skillsinc
I'm trying to setup 802.1x on my Yealink T48G to connect with certificates to my RADIUS NPS Server.
I have cloned the yealinkT4xeol.ph.xml template and added these options per the Yealink documentation for this phone:
network.802_1x.mode = 2
network.802_1x.identity = yealink
network.802_1x.root_cert_url = http://192.168.100.57:88/provisioning/ca.crt
network.802_1x.client_cert_url = http://192.168.100.57:88/provisioning/client.pem
Per the Yealink site, all these phones should now support the new templates, and when I'm in the web interface the help even calls them out like this, so why is the template in 3CX still using the old template style? Is this what is breaking the 802.1x setting from working?
static.network.802_1x.mode = 2
static.network.802_1x.anonymous_identity = Anonymous
static.network.802_1x.identity = yealink
static.network.802_1x.root_cert_url = http://192.168.100.57:88/provisioning/ca.crt
static.network.802_1x.client_cert_url = http://192.168.100.57:88/provisioning/client.pem
The phone is not picking up the provisioning template changes for 802.1x. I can see config changes like adding or removing BLF, but it ignores the 802.1x settings.
Is this because the templates have not been upgraded to match the new firmware?
I have even tried placing both sets of settings in the template and nothing works.
The firmware has been updated to 35.83.0.136 per the 3CX Console and the 3CX website list of supported firmware.
I have deleted the phone and added it back to make sure it was getting the new template.
Make the changes via the webui on one phone.
Download a backup of the phone config from the web ui of the phone
In 3CX navigate to the phones page, then hit +config to generate the config file. Copy/paste that in a window.
Compare the 2 files (exported config and what 3CX is generating. Find and isolate the needed config lines. Place them in the 3CX template in the correct spot.
Apply the new template to a phone and see if it works.
Almost certainly you are placing your config changes in the wrong spot in the template. Some spots are ignored via if/then statements.
SupportRock
