999 to hit VM when not in office
SCI
Intermediate Cert.
Hello everyone, I know we can hit 999 from a outside line when the client is using an IVR. This does not work thought when the client has the call to a "Q". Is there away around this? Thanks
Yes, call a different number that doesn't go to the queue :)
Get a DID.
Good option @Saqqara !
Except no IVR in use.
If you don't use the operator extension, you could use that, forwarded to an IVR that then has an option to go to 999. You don't have to announce this option. Because this would be reached by *, you could simply offer someone who "stumbled" on this, an option to leave a message, by pressing 1, but if you pressed ...say, 6, you'd go to 999, be asked for the extension number, then PIN. So...if you called your own extension, got voicemail, then starred out, you'd reach the IVR.
Have not actually used this, but worth a try.
But the calls are going to a Queue.
Then they are out of luck, if all calls, in the PBX, go to a queue.
  • Haha
Reactions: craigreilly
3K8iMGWviZ
