Abandoned Queue Calls
DXC
Hi there,
Is there any way to set up the time criteria to decide which the calls are meant "abandoned"?
For example, we need to exclude abandoned calls with ring duration less than 3 sec
Provided that you are referring to the "Abandoned Queue Calls" Report, then yes. Before generating the report you can enable the following option to exclude calls dropped under a specific number of seconds:
What about Dashboard statistics?
I'm afraid no, this is only available for the mentioned Report.
jmarshall
