Solved Ability to Import DIDs to Multiple Trunks for smooth porting?
ebrowne_sts
Platinum Partner
We were able to have the same DIDs on a system as long as they were on different trunks in v18. This made is easy to port DIDs from one SIP Provider to another without the customer noticing. Will this come back at any point?
You should be able to do this already
SG_F7
