Abounded calls info
mahmoud.hamdy
If the customer ended the call before being answered by the agent, can it be tracked, or reported as call details not just number of calls
If I want to get the ANI for example
Hello @mahmoud.hamdy
Are you referring to call queues calls? Are you running a report to get this info? Please clarify the request so we can better try to assist.
Yes, I want to get the data from the calls abounded before reaching an agent, abounded while waiting in queue
You can run a call report and select to view calls for the required dates and the desired queue extensions. You can also select to view only unanswered calls.
SaschaA_
