Act! Integration
Shep415
I have a client that would like Act! integration with 3cx. I've read that it is no longer supported by 3cx, are there any 3rd party or other solutions to this? Thanks.
We could probably build one for you if the customer has enough need for it.
You can also build your own template for this type of integration with the 3CX CRM Template generator
See the information at https://www.3cx.com/docs/crm-integration/
Hassan Murasan
