Active GSM calls should take priority over SIP calls
Quehl
I read here:
https://www.3cx.com/blog/change-log/3cxphone-android-build-history/
that it is possible that "Active GSM calls take priority over SIP calls, i.e. incoming SIP calls are rejected and forwarding rules are applied."
That was for the version: 3CX App for Android v16.1.0.39, BETA, September 2019
Can anyone confirm that this works ? With 16.2.0.93 on active GSM call i still get disturbing incoming 3CX-calls (internal+external) and 3CX-status is still green ("available") and not yellow. Or do i have to set somewhere ?
Or does anyone know a workaround without changing the status manually ?
When you have an active GSM call, the app should not ring.
The call will reach destination according to your current Status.
Mahlon
