Unsupported Add ext. No to BLF (Yealink)
Parslej
Forum User
Is there any way to add Ext No to BLF buttons ?
I have now:
John Doe
I'd like to have:
1234 | John Doe
I coudnt find any variable refering to blf ext No
This cannot be controlled from 3CX. The default behavior of the Yealink phones is exactly as you see it now.
It might be possible to do manually from the phone, however we would not recommend that as the phones will autoprovision daily back to their defaults.
You can do this with a custom template.
<extension>
<Line>1</Line>
<type>%%blfno%%</type>
<DKtype>16</DKtype>
<PickupValue>%%param::pickup%%</PickupValue>
<label>%%blfno%% %%blffirstname%% %%blflastname%%</label>
<value>fnc=sd+blf+cp;</value>
</extension>
Reactions: Parslej
Finatra.us
