Add more than one SPA to elastix server
Aiiar
Good day.
I want to ask, can I add more the one SPA3102 to the elastix server so I can use more than one land line with the server?
And what is the limits in this solution?
Thanks.
Yes, you may add as many as you need, or use any other device that has more ports.
You wont have any issue, because the other device will have another IP address, and you will need to create another sip trunk and handle it independently.
CLTedu
