Add multiple sip trunk at the same time
Xenz
Gold Partner
Hi all,
I need to add about 200 Sip Trunk, they have the same parameters. Is there any way I can add or import all at the same time.?
Thank you
Hi all,
Thank you
SIP trunks or DIDs? I doubt you need 200 trunks in any situations.
I agree, I don't see under what circumstances you would need so many trunks, but to answer your questions, what you could do is:
  1. Create 1 Trunk as you want it.
  2. In the Management Console go to "SIP Trunks" node, select the Trunk you created and press the "Export Provider" button and save the XML file to your desktop
  3. Then repeatedly use the "Import Provider" button to load that file again and again to create more with the same settings.
Hi Frederick, thank you. This is SIP Trunks
Thank for your reply. I tried to do your way. But in XML file, no parameter that specifies "Main trunk number". Each SIP trunk will have a different main trunk number
When you load the file again, you will get prompted to enter the Main Trunk Number.
Just because I'm curious: why the heck do you need 200 trunks?
Reactions: NickD_3CX
Thank for your support. Looks like this is the best way I can do this
Oh, my customer has 200 branches, and they want each branch to have its own line.
Is that because of something to do with outgoing caller ID requirements, from multiple extensions? Or, migrating a current system. Otherwise, I'm wondering why this could not be accomplished with one trunk group (maybe two), and 200 DIDs.
[email protected].
