Adding Extra Language Packs to 3CX?
MAWWICT
Hi all,
Just a quick query, is there any way at all we can add extra languages to 3CX, that are in addition to the ones they include as standard? (In our case we'd like to add Welsh)
It wouldn't be required within the back end/admin side of the system, just on the Web App for our end users.
I can see older posts from 2010 where it was possible to edit the languages and add your own translations, has that feature gone now?
There's a chance that this could be a big issue for us, and we'll need to stop using 3CX before it's even been fully rolled out. :/
So, from the prompts you can do a "Copy" which will create a new folder within 3cxpbx/instance1/data/ivr/prompts/sets which you can replace the files of.
edit: sorry you mean translation, dont believe you can do that.
Jake_Southern
