Solved Adding W52P to Extension
Scott EIT
Been a while since I've done this but followed the instructions https://www.3cx.com/sip-phones/manually-provision-yealink-dect/ and not had any joy. Not sure if I've missed something?
I've provisioned the base no problem and added the extension I want to use the handset in the extensions section but the phone's not appearing in the phones group or the extension I've added the phone to? Have I missed an additional step?
Reactions: Scott EIT
DECT phones are in Advanced > FXS/DECT. Not under the extension itself.
As above, for example
After you added the extension, reprovision the base unit
Check ip blacklist then. if the base provisioned and you are local but the base accounts are showing failed registration, its likely a blacklist issue.
Nailed it CentrexJ. Many thanks!
Reactions: CentrexJ
Finatra.us
