Additional visual feedback for incoming calls
Slideform
Intermediate Cert.
Hi there,
I'm looking for a solution that involves adding a light signal to incoming calls.
In use are Snom M700 dect stations with several mobile devices in an area with loud noises.
I thought of adding ambulance lights that light up once a call is incoming.
Problem is I havent found anything that is controllable with the 3cx.
Well, one thing "CyberData 011376 SIP RGB Multi-Color Strobe" for 650$ a piece... Which is a "little" bit overpriced.
Does anyone have an idea on what I could use instead?
Best regards,
Felix
You could use a Snom or Fanvil PA and connect it to lights/speakers.
Reactions: Slideform
Use an ATA connected to any device designed for an analog phone line. They tend to be less expensive, and offer more variety than SIP devices. There are "boxes", that use ringing current to operate a relay, that will control any AC powered device plugged to it.
We built an integration BusyLight. It is a USB connected light, but the light is small (about the size of a golf ball)..
gmacinit
