Solved Adhoc Conference calls not working
Reso
Server OS : Windows 10
3CX Version: 16.0.676
Phones: Grandstream 2135 and 1628 with the supported firmware.
I have an odd problem. I am trying to create ad hoc conference call (https://www.3cx.com/blog/voip-howto/create-conference-using-desk-phone/) using the above mentioned models. I can call 700 from all phones and get the voice prompt. However it doesn’t create or let me join a conference call. After a few seconds it says “Invalid Pin Number”. I don’t have a Pin set for the organizer to enter.
Here is the odd part. I can make and join conference calls on model 2135 WITHOUT phone provisioning. If I provision it says “Invalid Pin number” again. The models 1628 gets the voice prompt “Invalid Pin number” either provisioned or not. Please help.
You probably have a PIN requirement. Read the article again on step 2. You will find your PIN in the management console under Settings > Conferencing > Audio
Note: We are discussing in the context of properly provisioned phones without custom templates to get the expected behavior.
Thats the problem. I removed the PIN requirement but its still giving me the same voice prompt. The only phone i can make the conference call is 2135. That also without provisioning. Once i provision that phone, i get the voice prompt "invalid pin number".
  • 3CX Version, Standard Annual 16.0.676
  • Server OS, Windows 10 pro
  • Is the 3CX Server Hosted and where? hosted on premise
  • IP Phone Make/Model/Firmware Grandstream 2135 and 1628, 1.0.9.135 and 1.0.4.132 respectively.
  • Provisioning Method: Local LAN
  • Trunk Provider or Gateway Make/Model: No trunk yet as it is in testing.
  • Has the Firewall Checker passed: I haven't checked this as I am not doing any outside calls testing yet
  • Are custom Phone Templates being used: No custom templates
Hello, above are the requested details. I am still trying different ways to do this. Will update. Thank you.
12/05/2019 12:40:53 PM - Endpoint Extn:108 has refreshed contact <sip:108@XXXXXXXXXXXXXXX:5060/UDP>
12/05/2019 12:40:17 PM - Stop call record for leg L:1.1[Extn:108]
12/05/2019 12:40:17 PM - Removing leg L:1.1[Extn:108]
12/05/2019 12:40:17 PM - L:1.1[Extn:108]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
12/05/2019 12:40:17 PM - Leg L:1.1[Extn:108] is terminated: Cause: BYE from XXXXXXXXXXXXXXX:5060
12/05/2019 12:40:17 PM - Call(C:1), Extn:108 on entry: DlgInfo(1-3762/Terminated / I)
12/05/2019 12:40:17 PM - Notify dialog-info: Extn:108: sip:108@XXXXXXXXXXXXXXX:5060, Call(C:1)
12/05/2019 12:40:17 PM - L:1.1[Extn:108] got Terminated Recv Req BYE from XXXXXXXXXXXXXXX:5060 tid=779291063 Call-ID=YYYYYYYYY:
BYE sip:700@XXXXXXXXXXXXXXX:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXXXXXXX:5060;branch=z9hG4bK779291063;rport=5060
Max-Forwards: 70
Contact: <sip:108@XXXXXXXXXXXXXXX:5060>
To: <sip:700@XXXXXXXXXXXXXXX>;tag=c21fc118
From: "Hussain Rasheed" <sip:108@XXXXXXXXXXXXXXX>;tag=1257251752
Call-ID: YYYYYYYYY
CSeq: 112 BYE
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Supported: replaces, path, timer
User-Agent: Grandstream GXP2135 1.0.9.135 000b82d0c324
Content-Length: 0
12/05/2019 12:40:17 PM - L:1.1[Extn:108] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=779291063 Call-ID=YYYYYYYYY:
SIP/2.0 200 OK
Contact: <sip:700@XXXXXXXXXXXXXXX:5060>
To: <sip:700@XXXXXXXXXX>;tag=c21fc118
From: "XXXXXXXXXX" <sip:108@XXXXXXXXX>;tag=1257251752
Call-ID: YYYYYYYYY
CSeq: 112 BYE
Content-Length: 0
12/05/2019 12:40:17 PM - Call(C:1), Extn:108 on exit: DlgInfo(1-3762/Terminated / I)
12/05/2019 12:40:17 PM - Call(C:1), Extn:108 on entry: DlgInfo(1-3762/Confirmed / I)
12/05/2019 12:40:17 PM - Notify dialog-info: Extn:108: sip:108@XXXXXXXXXX:5060, Call(C:1)
12/05/2019 12:39:59 PM - Leg L:1.1[Extn:108]: session is confirmed
12/05/2019 12:39:59 PM - Call(C:1), Extn:108 on entry: DlgInfo(1-3762/Confirmed / I)
12/05/2019 12:39:59 PM - Notify dialog-info: Extn:108: sip:108@XXXXXXXXXX:5060, Call(C:1)
12/05/2019 12:39:59 PM - L:1.1[Extn:108] got Confirmed Recv Req ACK from XXXXXXXXXXX:5060 tid=514077122 Call-ID=YYYYYYYYY:
ACK sip:700@XXXXXXXXXXXX:5060 SIP/2.0
Via: SIP/2.0/UDP XXXXXXXXXXXXX:5060;branch=z9hG4bK514077122;rport=5060
Max-Forwards: 70
Contact: <sip:108@XXXXXXXXXXX:5060>
To: <sip:700@XXXXXXXXXXXX>;tag=c21fc118
From: "XXXXXXXXXXXXX" <sip:108@XXXXXXXXXXX>;tag=1257251752
Call-ID: YYYYYYYYY
CSeq: 111 ACK
Proxy-Authorization: Digest username="XXXXXXXXXXXXXXX", realm="3CXPhoneSystem", nonce="XXXXXXXXXXXXXXXXXX", uri="sip:700@XXXXXXXXXXXXXX", response="XXXXXXXXXXX", algorithm=MD5
Content-Length: 0
I enabled verbose logging and made a call to 700 and dialed a conference ID. I got the same "invalid pin number". Above is the resultant log. Please let me know if i am missing anything
ok. I tried to do more tests, however i couldnt this time. Provisioned or not.
Earlier I had added a extra IP address of a different subnet to the 3cx server because i was doing another test on phones of that subnet. (the phones i used to test conference were on the same subnet as the 3cx server). I removed that IP and restarted the phones (provisioned) and the server and now everything is working fine :) . Thank you all who commented.
I'm glad to hear it was resolved
Kayla Norris
