Admin Password change
Rmn3
Hi guys,
in the 3cx management console, is there any chance to change my own password?
Thanks in advance.
Security -> Admin Credentials.
Unfournately i dont have any chance to change my password there. Under the Point Security i only have attack protection, countrycodes, blocked numbers, console entrance, ip-blocklist, secure sip and 3cx-tunnel
Sounds like you're not the main admin. In which case, you should edit your password from the web client > General
Unless you're using hosted 3cx..
are you logged in the console as admin user - in the top right do you see uppercase A
If you are logged in as admin, these are the options you should see
aatroxadrian
