Advanced Outbound Prefix
JCubio
Hi all,
Does 3CX support some sort of advanced outbound prefix?
We have 2 local PSTN Lines that have multiple prefixes for each provider. We want to integrate that into our outbound rule but the list is too long and it would be difficult to manage.
Please see sample image :
13335
If all 092X went to one provider, then that would only require one rule. Same as if all 097X went to one. If the fourth digit could go to either, then you'd require 10 rules per prefix. I don't really see any way around this. Hopefully, you just have to do it once, and not be making constant changes.
Reactions: JohnS_3CX
Sad. I need to create around 50 outbound rule for 1 provider alone
I assume that doing this will get you a better rate, when routing certain numbers, to a particular provider.
I guess that's the price you'll have to pay.
Reactions: JCubio
3K8iMGWviZ
