- Joined
- Jan 26, 2016
- Messages
- 65
- Reaction score
- 2
Hello
I have an issues where at random some extensions stop receiving calls from any queue
Agents use 3cx from Windows
They are logged in, available, no forwarding, and had no issues a day prior
And this happens at random as well
There are no call stuck, I checked Active calls.
Agent with this issue is part of other queues as well (but cannot accept calls from any queue)
Polling strategy - Longest waiting (but there are several calls waiting, and the agent with the issue is the only one not on call)
Wrap-Up Time = 20 seconds, but agent is in queue for much longer (From beginning of the day)
Tunnel is enabled between agent and 3cx server (disabling it doesn`t help)
Re-registering doesn`t help
Deleting account and then re-applying config file from welcome email doesn`t help
The only way it works again if the extension is deleted completely from 3cx Management Console and recreated, then added back to all queues
P.S. I saw some threads about it earlier, but no definitive answer
I hope the issue is found from 3cx side and will be fixed soon
