AI Agent using UK Voice
curveball
Gold Partner
Does anyone know how to change the AI agent voice to a UK voice?
Thanking you in advance for your help with this query.
Regards
Steve
The AI voices are provided by OpenAI and are a bit on the American side of English tone - still, I have had some good results by adding
"- You use a British English intonation, choice of phrasing and language patterns. Avoid Americanisms." or similar. Give it a try. Also changing the welcome message to a more British one can help set the tone.
Hi Kyriacos,
I will give it a go.
Thank you for the feedback - Much appreciated.
Hi Kyriacos,
Sorry - Can you confirm where you paste in the text?
Just want to make sure I do it correctly.
Reactions: PaulC_3CX
Hi Kyriacos,
Its Ok I have worked out where to paste the text.
It is slightly better but there is still an american style voice on occasions.
Thanks for your help.
Stick in "..in the voice of Stephen Fry" somewhere and hope for the best :D
Do switch around with the different Voice Style settings - all are fairly american, but some take those prompt instructions better. Point of note, the instructions being added really go to the text generation engine, not the text-to-voice engine, so there is a limit to their effectiveness..
Hi Kyriacos,
I have gone though all Voice Styles and the only one that sounds close to UK is "ballad".
We will set up with this for testing.
Thank you for you help.
Hi Kyriacos,
Where did you add this in the end?
Hi Kyriacos,
I pasted the below;-
I also changed the Voice Style to ballad as this was the only one that sounded anything remotely like UK English.
I do think 3CX should provide better voice options for AI Voice Style country specific.
Thanks, it makes a big difference immediately so cheers.
It is an oddity of English (perhaps Spanish too?) that the accents provided by OpenAI are all american - non-english languages sound normal for their core country. As the things mature and more voice models become available this is likely to be solved, for now we are providing all the options we can.
If anyone wants to take a deaper dive into language tuning:
https://developers.openai.com/api/docs/guides/realtime-models-prompting/
Zexus
