All Log data are gone after a reboot
Rene Poels
Due to importing contacts in the database, I have to restart all 3CX services at night to be able to show them in the 3CX Clients. (Still working on a better way)
After restarting all services, all call logs are gone which make my longterm reports useless.
Is it by design that all logs are gone upon a reboot?
Hello @Rene Poels
Call logs are never deleted unless purged by the user or deleted from the database. Activity logs and event logs are cleared after a reboot however.
Did you import the contacts from the management console or did you import them directly to the database?
They are imported directly to the database
Please note that direct access to the database is not supported and should be avoided in all circumstances. Hopefully you have a backup of the system so you can restore your call history.
Zexus
