Alternative headset for Yealink?
Alphabetic
3CX MVP
Im struggling to find any stockists with WH62 headsets.
Does anyone know of any DECT alternative that comes with charger stand that can plug in to a Yealink via USB and work?
Where are you checking? I checked 1 distributor this morning and they had 30 in stock ready to ship right now. I assume between the 5 or so distributors I usually use I could have hundreds in the mail before the end of the day.
But to answer your question, here's a supported list from Yealink for you to review?
https://www.yealink.com/upfiles/pbx...compatible-with-Yealink-IP-Phone-V84-V8.0.pdf
What country are you in? You might be able to order from Amazon if your local Yealink distributor doesn't have stock.
imelda
