Solved Alternatives for Options Remove
tony28
Forum User
Console Restriction is removed from 3CX hosted. Is there an alternative of implementing it?
I used to go to License tab to change the 3CX sender email address name. Where can I change it now?
When I upload IVR wav prompts, how to delete them since no ssh access?
With no access to Phone/Apps Options, how does it affect Google Firebase Push messages to notify 3CX Android app for incoming calls?
When you switch from 3CX hosted to self host, does it automatically remove/delete the instance from 3cx server
The alternative for you would appear to be to use your own cloud account. There is no need to access Google Firebase, this is all handled by 3CX. See forum sticky how to migrate back from 3CX hosted to your own instance.
Robert Lee
