Solved Android App Beta v 20.0.0
Allen_Miller
I installed the version 20.0.0 today after reading the blog post (which might be improved my mentioning the version number).
I don't know if this is intentional but when I did a search on the name 'ryan' I got one page of results but it only went through first names starting with C so it fell far short of finding my contact. It found a lot of Bryan names.
Using Google Pixel 8 Pro w/ Android 14.
Allen
1699909806041-png.38204
Hi @Allen_Miller
Thanks for your feedback. Could you kindly confirm if the Webclient gives you the same results when searching for the same search crieteria please?
Hi Thom,
The Webclient gives a different result and did in fact include the contact I was looking for.
Thanks.
Allen
@Allen_Miller is the PBX v18 or V20?
Can we have the exact version of the PBX please?
sure. it is 18.0 (Build 939)
SDNM
