Announce Queue position to caller
Tycoon Master
Is there any way one can reduce the volume for this and also choose a custom voice for this?
There are no options for this I’m afraid and the prompt cannot be changed with 3CX Free or 3CX SMB.
Hello charles,
For claification, so there is no way to control the volume? The 3CX is a 4SC Pro edition not a free/SMB.
There are no settings to control volume of prompts no.
In dedicated instals you can replace prompts but the position numbers are separate prompts wav files as is the position announcement prompt. Re recording prompts or downloading them then using an audio tool to reduce volume of the audio, exporting them and replacing the current prompts is required to achieve this outcome.
Reactions: IrinaP_3CX
Thanks for the clarification it is now clear. Your prompt response is appreciated.
martin1176
