Any way to get a report that just has destination if no answer?
robort
Forum User
Is there a way to get a report that just has destination no answer on?
trying to get to the bottom of why on an agents screen the abandoned call number is always higher than in an abandoned call report?
In a call reports you can filter with unanswered only.
We dont have a report just for no answer.
thanks - any ideas why the abandoned calls number in the dashboard is always higher than in abandoned call report?
Maybe in the report you checked the box " Exclude calls dropped before"?
So the abandoned calls under some seconds are not in the report?
thanks but if you are logged on as the agent and go calls / abandoned calls this is less that the figure at the bottom too? any idea what the figure includes at the bottom of their dashboard? thanks
Using the 3rd party product "CallSequitur" you can pull a report for almost anything. Here below you can see I chose "Outgoing" only, Answered = "No", no specified timeframe so I ended up with 2,850 out of 82k calls in the database. Clicking on the "Call ID" will display yet another window with all of the details of that particular call. Highly recommend you check into this product for any 3CX reporting issues.
Reactions: JosIPVG
WinSip
