Solved Anyone with some experience on Alcatel IP1550
AWS2P
I've to setup a meeting phone Alcatel IP 1550 SIP, this is a phone provided by my customer on which I have no experience at all.
Have you already used one, if so, is it friendly to setup or not ?
13102
Any advise would be appreciate, thanks.
It looks to be a SNOM C529, but firmware may be Alcatels own concoction.
Hi Leejor, Yes you are Surely right found a snom C520, seems the same hardware surely all coming From RTX
Some REX to say what i did to have it working (easily) with 3CX V16 SP4 on OVH cloud phone behind an SBC (windows version)
First i got admin manual PDF file as in the phone box there's a quick guide only with no technical infos. PDF Admin file is here
You need to follow instructions for conference IP1850 model.Default credentials are admin admin
  1. Choose your preferred language for web GUI and phone, to do this go in preferences menu13922
  2. Network, by default DHCP is enabled, i change it to static from network menu13923
  3. Create an account on 3CX side
  4. Phone has no template as it is unsupported one, so account settings are done manually13924
  5. Change audio codec to your preferred13925
  6. check in 3cx console if phone is registred13929
Now enjoy your new phone, is ready to work.
Reactions: Clément Rousseau
Kayla Norris
