API error asking for Delta Field
stubh
Titanium Partner
I am setting up for some API requests and I keep getting an error message asking for a "delta" field value. I am able to get an auth token, and am able to make a few get requests and am seeing the expected output data, but when I make a post request, it keeps failing. I could not find anything on the GitHub repo mentioning a delta value, or on the page for the config documents.
https://www.3cx.com/docs/configuration-rest-api-endpoints/#h.kj2s8xpn0hts
Has anyone encountered this and if so, how did you solve this?
No problem known to me.
Can you please clarify the folowing details:
-Version 3CX server (example v20 update 6 release 721 Beta)
-Type of installation / license (example private cloud 16 pro)
-Used programming language (example linux python)
-Example of POST function used (example GeneralSettingsForApps)
I understand it seems general, still it would be good to drill down to where the problem occours.
If possible, i will try to replicate
Paulo
Reactions: stubh
Daily using 150+ servers, in this way with mass changes.
Paulo
Getting it on two server instances.
I am having the issue in two instances that I am testing.
Version 20.0 Update 6 (Build 486 Alpha)
Type Enterprise Annual On Premise
Version 20.0 Update 5 (Build 551 Release)
Both Give the same error
Language Python, but having it the automation software we are using as well. But if I can get it in python, I can work backwards to get it to our autotmation software.
POST method being called is the xapi/v1/contacts for the
CreateContact operationId based on the swagger.
Let me know if you need any more information from me
Send first to check extension (example of GET):
https://{{PBX_FQDN}}/xapi/v1/Users(65)
JSON:
    "@odata.context": "https://{{PBX_FQDN}}:{{PORT}}/xapi/v1/$metadata#Users/$entity",
    "Enable2FA": false,
    "Require2FA": false,
    "MyPhoneShowRecordings": false,
    "MyPhoneAllowDeleteRecordings": false,
    "MyPhoneHideForwardings": false,
    "MyPhonePush": true,
    "RecordCalls": false,
    "AllowOwnRecordings": true,
    "RecordExternalCallsOnly": false,
    "RecordEmailNotify": false,
    "PrimaryGroupId": 3,
    "FirstName": "",
    "LastName": "extension",
    "DisplayName": "extension",
    "EmailAddress": "",
    "Mobile": "",
    "WebMeetingFriendlyName": "",
    "WebMeetingApproveParticipants": false,
    "SendEmailMissedCalls": false,
    "VMEnabled": false,
    "VMEmailOptions": "None",
    "VMPIN": "",
    "VMDisablePinAuth": false,
    "VMPlayCallerID": false,
    "VMPlayMsgDateTime": "None",
    "ContactImage": "",
    "IsRegistered": false,
    "CurrentProfileName": "Available",
    "QueueStatus": "LoggedIn",
    "AuthID": "",
    "DeskphonePassword": "",
    "AuthPassword": "",
    "OutboundCallerID": "",
    "Blfs": "<PhoneDevice><BLFS/></PhoneDevice>",
    "OfficeHoursProps": [
        "GlobalSchedule"
    "Language": "en",
    "Internal": false,
    "Enabled": true,
    "PromptSet": "",
    "HideInPhonebook": true,
    "Tags": [],
    "PinProtected": false,
    "PinProtectTimeout": 0,
    "CallScreening": false,
    "AllowLanOnly": true,
    "SIPID": "",
    "MS365SignInEnabled": true,
    "MS365ContactsEnabled": true,
    "MS365CalendarEnabled": true,
    "MS365TeamsEnabled": true,
    "GoogleSignInEnabled": false,
    "GoogleContactsEnabled": true,
    "GoogleCalendarEnabled": true,
    "EnableHotdesking": false,
    "SRTPMode": "SRTPDisabled",
    "PbxDeliversAudio": false,
    "EmergencyLocationId": "",
    "EmergencyAdditionalInfo": "",
    "CallUsRequirement": "Both",
    "CallUsEnablePhone": false,
    "CallUsEnableChat": false,
    "CallUsEnableVideo": false,
    "ClickToCallId": "",
    "Number": "111",
    "TranscriptionMode": "Inherit",
    "Id": 65,
    "Hours": {
        "Type": "OfficeHours",
        "IgnoreHolidays": false,
        "Periods": []
    "BreakTime": {
        "Periods": []
Then send POST to create new user:
JSON:
    "AccessPassword": "QrzxYQwa5!",
    "EmailAddress": "[email protected]",
    "FirstName": "TestFirstName",
    "Id": 0,
    "Language": "EN",
    "LastName": "TestLastName",
    "Number": "211",
    "PromptSet": "1e6ed594-af95-4bb4-af56-b957ac87d6d7",
    "SendEmailMissedCalls": true,
    "VMEmailOptions": "Notification",
    "Require2FA": true
Response from the POST above:
JSON:
    "Enable2FA": false,
    "Require2FA": true,
    "PrimaryGroupId": -1,
    "DisplayName": "TestFirstName TestLastName",
    "Mobile": "",
    "VMEnabled": true,
    "VMPIN": "365594",
    "ContactImage": "",
    "AuthID": "",
    "AuthPassword": "",
    "Blfs": "",
        "GlobalSchedule"
    "Language": "EN",
    "Internal": false,
    "Enabled": true,
    "HideInPhonebook": false,
    "Tags": [],
    "PinProtectTimeout": 60,
    "SIPID": "",
    "GoogleSignInEnabled": true,
    "Number": "211",
    "Id": 207,
    "Hours": {
        "Periods": []
    "BreakTime": {
        "Periods": []
Hope this helps
Paulo
Reactions: stubh
https://{{PBX_FQDN}}/xapi/v1/Users(63)
XML:
    "Enable2FA": false,
    "PrimaryGroupId": 36,
    "FirstName": "",
    "EmailAddress": "",
    "Mobile": "",
    "VMEnabled": false,
    "VMPIN": "",
    "ContactImage": "",
    "AuthID": "",
    "AuthPassword": "",
        "GlobalSchedule"
    "Language": "nl",
    "Internal": false,
    "Enabled": true,
    "PromptSet": "",
    "Tags": [],
    "SIPID": "",
    "ClickToCallId": "admin",
    "Number": "100",
    "Id": 63,
    "Hours": {
        "Periods": []
    "BreakTime": {
        "Periods": []
XML:
    "Id": 0,
    "Language": "EN",
    "Number": "211",
    "Require2FA": true
XML:
    "Enable2FA": false,
    "Require2FA": true,
    "Mobile": "",
    "VMEnabled": true,
    "VMPIN": "365594",
    "ContactImage": "",
    "AuthID": "",
    "AuthPassword": "",
    "Blfs": "",
        "GlobalSchedule"
    "Language": "EN",
    "Internal": false,
    "Enabled": true,
    "Tags": [],
    "SIPID": "",
    "Number": "211",
    "Id": 207,
    "Hours": {
        "Periods": []
    "BreakTime": {
        "Periods": []
Hope this helps
Paulo
That is what I have been doing. I making the get request for users or contacts and it will give me everything out. But when I make a post request I am getting back this error for making a new users with the text XML you provided. I get that with make contact, and make user. I have not tried update as of yet.
{'response': {'error': {'code': '', 'message': 'The input was not valid.\n\ndelta:\nThe delta field is required.', 'details': [{'code': '', 'message': 'The input was not valid.'}, {'code': '', 'message': 'The delta field is required.', 'target': 'delta'}]}}, 'status': 400}
sorry to hear this.
So if everything is good, it must be some 3CX server installation f-ck-up or database corruption.
My personal next step would be backup of 3CX, re-install Linux, re-install 3CX- Restore Backup - try again.
But that's me, not sure if this is an option for your setup.
Paulo
Reactions: stubh
Made a few tweaks to the request. I was able to get make contact working, which for the project I am on, gets me moving, so I will go from there. Still not able to create a user, gives the same delta field error. Which is a bit annoying since it works for one but not the other. I appreciate the help!
do you know the appication POSTMAN.
With Postman, you can test the send and receive of GET and POST messages and 'see' what is happening.
Normally I test it in Postmann, and than it should work in my own APP... if not it's a long night xD for me.
If you do use it, than i am sorry to have mention it, but great to hear you are onboard.
Paulo
I use python, I should spin up a postman instance for myself specifically for this project since I know once I get this up and running, there is going to be a lot of demand to automate stuff. Since each org has their own FDQN and secret, how are you handling that generally to access and make global changes easily and scalably?
I work in PHP (website)
Paulo
What fixed it at least for getting contacts made and deleted was having a unique header for the auth with was using
content-type application/x-www-form-urlencoded and then all other things use the application/json in the header. Still throws the delta field error when trying to make a new user, but that is a different problem for a different day.
Subject1725
