API Post missing custom variable since update to V18
Joshh
Hi All,
Prior to upgrading to V18 our CRM integration was working with no issues - After each call it hits our api and passes the below information, one key part being 'CustomerID'
Since V18, this is always blank/missing. The client is still hitting the api and doing a lookup, the response object is the same, template is the exact same but now the 'ContactID' object seems to not be being pulled through
Has something changed with this since V18 that would cause this to suddenly stop working? It went from 100% of all api hits including customerID, to 0% (Variable is there, but its just a blank string)
Variables being setup:
XML:
  <Variables>
        <Variable Name="ContactID" Path="customer.CustomerID">
          <Filter />
        </Variable>
        <Variable Name="FirstName" Path="customer.Details.Name">
          <Filter />
        </Variable>
        <Variable Name="LastName" Path="customer.Details.Surname">
          <Filter />
        </Variable>
        <Variable Name="Email" Path="customer.Details.Email">
          <Filter />
        </Variable>
        <Variable Name="PhoneMobile" Path="customer.Telephone">
          <Filter />
        </Variable>
      </Variables>
one of the Requests - Essentially the [Contact::ContactID] bit seems to be blank now, whereas before it would (Correctly) give the variable set. This template was not touched at all, only change was upgrading to V18
XML:
    <Scenario Id="ReportCall" Type="REST">
      <Request SkipIf="[ReportCallEnabled]!=True||[CallType]!=Inbound" Url="api url" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues Key="">
          <Value Key="duration" Passes="1" Type="String">[Duration]</Value>
          <Value Key="phone" Passes="1" Type="String">[Number]</Value>
          <Value Key="agent" Passes="1" Type="String">[Agent]</Value>
          <Value Key="callType" Passes="1" Type="String">[CallType]</Value>
          <Value Key="DateTime" Passes="1" Type="String">[DateTime]</Value>
          <Value Key="CustomerID" Passes="1" Type="String">[Contact::ContactID]</Value>
          <Value Key="CallStart" Passes="1" Type="String">[CallStartTimeUTC]</Value>
          <Value Key="CallEnd" Passes="1" Type="String">[CallEndTimeUTC]</Value>
        </PostValues>
      </Request>
      <Variables />
      <Outputs Next="ReportCallMissed" AllowEmpty="true" />
    </Scenario>
In v18, there are no [Contact::XXXXXX] variables anymore. You need to return the outputs EntityId and EntityType during contact lookup / creation, and then you can access those values during Call Journaling with variables [EntityId] and [EntityType].
Please check the updated XML description here:
https://www.3cx.com/docs/server-side-crm-template-xml-description/
Hey thanks for the speedy reply
Just to clarify, if i change the customerID line where it references [Contact::ContactID]
to [EntityId]
Ie if i edited my template to have the following would that do the trick? Or should i edit my JSON response from the API to have 'EntityID' and then not include it in Variables? and then just use the second XML section? ie just edit the Scenario(s)
XML:
 <Variables>
[B]        <Variable Name="EntityID" Path="customer.CustomerID">[/B]
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
      </Variables>
XML:
        <PostValues Key="">
[B]          <Value Key="CustomerID" Passes="1" Type="String">[EntityID]</Value>[/B]
        </PostValues>
      </Request>
      <Variables />
    </Scenario>
to [EntityId]
XML:
 <Variables>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
          <Filter />
        </Variable>
      </Variables>
XML:
        <PostValues Key="">
        </PostValues>
      </Request>
      <Variables />
    </Scenario>
Yes that should work. Remember to set the EntityId in the Output also.
Reactions: edossantos
NathanMitchell
