API to trigger calls
Cesar Mansilla
Hi all!!
You know if we already have the API to trigger calls, I need to trigger calls from another app !!!
Nope, as of now there isn't.
Hope for the best with the upcoming REST API with the Gateway Service of V18. Probably will be in U1 or something like that but it should be there eventually.
Reactions: edossantos
We are going to need more information about the other application. For example, if this is a desktop application then you can use the CallTriggerCmd.exe included with 3CX Phone for Windows to initiate a phone call.
If that will not work for you, then we have a VoIPTools REST API that can invoke a MakeCall. The free version of our API can perform a MakeCall.
lastshadow
