Unsupported Applying i53W custom template...no go
chiz
SOHO User
I'm relatively new to 3CX, so I apologize if I'm missing something obvious here...
I'm evaluating a Fanvil i53W - I know it's not officially supported by 3CX, but I see mentions of it in other posts where it sounds like people have it working. Fanvil tech support sent me a custom template for i53W. I added the template in 3CX (3CX Pro 18.0 Update 8 Build 912), restarted services, and now I see i53W as a choice under Custom in the phone type list.
When I factory reset the phone and put it on the local network, 3CX discovers the phone and recognizes it as an i53W (did so even before I added the template), but I can't do anything with it. All of the options are grayed out except for "Reject." I can't follow the 3CX instructions for a custom template phone because it says to select Add or AssignExt - those are always grayed out. I tried going into a user and adding the phone there, selecting the custom template, and pasting the MAC address, and hitting OK. But that never links the phone to the extension - in the phone list it always remains with all options grayed out except Reject. The Reprovision option is also always grayed out.
I've tried other things:
  • tried i53W firmware 2.12.6 and 2.12.9 (latest)
  • tried fully restarting the 3CX (locally hosted) server (in case I didn't restart the right combination of services)
I'm open to trying anything else you might suggest to get this working... THANKS!
Hi @chiz since this is not a supported device you will need to manually configure it.
If Fanvil has provided you a template, then please enter in contact with them so they can assist you configuring the device properly.
You can check the supported device list here
Have a great weekend!
We were able to get i53W's working with manual configuration. In 3CX version 18, I used the i56A template then copied the authentication information from 3CX into the web settings of the i53W. The 3CX manual configuration instructions provided the key steps for that part.
LeeonLau
