Are DigitalOcean API Tokens Used After Installation is complete?
bdpbxer
I received a notification from DigitalOcean saying that legacy API tokens will lose read and write access to APIs on March 31, 2023. New API tokens must be generated by that date. There doesn't seem to be any way to update tokens in 3CX. So after the system initial deployment, is the API token used again for any purpose? Is it used to complete updates? If the original API token used during deployment to DigitalOcean is removed or otherwise terminated, will that cause any issues with 3CX at all?
If the DigitalOcean API token is used after initial deployment is complete, how do I update it in 3CX?
Reactions: jjmorphew
Graham Robertson
