Audio Delay on Call Pickup 3CX Desktop App
LanceK
Hello, hope you're doing well.
I am having an issue with one PC having a 5 second delay between when the call is initiated and when audio is sent/received. The delay is the same length every time incoming or outgoing and the issue is only occuring on one PC and only with the 3CX app, I configured a different Softphone (MicroSIP) for testing and the issue was not present then. The user is currently using the mobile app instead due to the delay and they are not having issues there.
I am using Version 18.8.508 of the Desktop App, the issue occurs if I use a different extension on that PC, I've uninstalled and reinstalled the 3CX Desktop App and audio drivers, setup a different extension on the PC and created a new user profile on the PC and the issue repeated itself.
The PC specifications:
OS: Windows 11 Pro
Make/Model: Surface Book Pro 2
RAM 8GB:
CPU: i5-8350 1.9ghz
  • 3CX Version: 18.0 Update 3 (Build 461)
  • Server OS: Debian 9
  • Is the 3CX Server Hosted and where? Yes, Digital Ocean
  • IP Phone Make/Model/Firmware version 3CX App
  • Provisioning Method: 3CX App
  • Trunk Provider or VoIP Gateway Make/Model: Aatrox Communications
  • Has the Firewall Checker passed: Yes
  • Are custom Phone Templates being used: No
Jeff_MKC
