So a bit more info. The problem is not isolated to the shared parking on pstn calls. There is also a problem recording digital receptionist recordings. The system allows you to make a new recording, but the recording is silent. If we make a 10 sec recording and play it back, we hear 10 sec of silence. (Even if we download the wav file, it will be 10sec of silence)
I've attached 2 packet captures.
PARKING DUMP
Shared parking capture events.
Ext 7501 calls 807738xxxx
call is established
Ext 7501 places call on shared park 1
Call is picked up on ext 7500
call is established between 807738xxxx and ext 7500
no audio
hang up
https://drive.google.com/file/d/1tmvar-Q6PtvX2Pk7-hNsK-O6RhkYaXj0/view?usp=sharing
IVR DUMP
Setup new digital receptionist
record message using ext 7500
ext 7500 rings, i answer and follow prompts to record
i recorded the message twice and pressed 0 to save
hang up
play back the message, just plays silence
FYI: The Patton is a Smartnode (fully supported), the pbx (windows 10 HPE micro server), Phones (yealink t58 and 2x yealink t41s, 2x grandstream gxw4248 are all directly connected to the same switch(cisco sg300 poe switch)
