AudioCodes MP-11x 5.2 Firmware
sunspark
Forum User
Can any of you PM me and send the 5.2 revision of the AudioCodes MP-11x firmware?
im trying to upgrade with V6 using AcBootP , but it doesnt works , after 96% a have : Transmissions failed.
I assume that this question has been raised due to the fact that you cannot get firmware files for Audiocodes devices unless you have a paid support contract or a a high level partner ?
If you want you can PM me the file over and I will see if I can load it up on one of my devices here but can presume that it is failing due to the fact your are jumping some versions.
yes , this is exactly what happend. i can't create an account because we are not a partner...
and i'm not able to find the 5.x version to rollback.
[email protected]
thanks !
Yes im not happy about this myself as I have my own 2600 SBC here that I use for testing and where I am not a partner need to keep it on the latest and greatest version. Luckily I managed to source 7.20 firmware from the place I bought it from.
did you find the V5 ?
Can you PM me with a link (like dropbox) on here and I will take a look.
bosdorf
