Authentication only with password
BestiAA
Hello. I try to connect Hytera with 3CX.
In settings I can't set my id - only password. How I Can to connect it. See picture for details
UPD: If you see to "Gateway ID" - this is not id in PBX, this is an internal id in Hytera config
If the Phone Gateway ID is the User, on the PBX, and you cannot change that in the device, then you'd have to create an extension, on 3CX, using the same number. I assume it is an extension, and not a trunk.
You might want to confirm that is the case.
Thanks for reply. Just in case, I already did it and this is my extension number
Cloudstar
