Authorization id to be complex
international4
Platinum Partner
For authentication security normally only password need to be complex not the username, new version of 3CX also require the authenticatio id to be complex also, that's is not logical implementation.
And It will also help that 3CX have a parameter to disable the above requirement as in case of Microsoft Windows.
The Authentication ID is for phone provisioning, Yes it would seem that it is logical to have that complex as well, unless of course you want someone to hack your phone account and make international calls on your dime.
the very complex authorization password should be enough.
We need the authorization id to be identical to the sip so I can easily debug the register message.
It should be just like you can use your name as windows username and a complex password should be fine.
@international,
Did you resolved this problem?
Regards
DaanLosning
