Auto answer the incoming call
developerzeeshan
Hi sir how can i auto asnwer the incoming call for a agent extension when ever call comes to that agent it auto received and status goes to crm
Hi @developerzeeshan,
There is an option in the new 3CX Windows App but the agent can disable it themselves, and it cannot be forced.
You can find it under Settings >> Advanced Settings.
With regards to opening the CRM when the call comes in, you can configure this in Settings >> Advanced Settings >> Behaviour:
can you tell me why its ping this url some times and majority its not ping the url as i am receving call in this extension ringing type
How often does it not open the Contact URL? Is this intermittent or can it be reproduced? Have you ensured that your popup is not being blocked?
Can you tell me one more thing how can i transfer the call from crm is there api to transfer the call
Currently 3CX does not offer a REST API for performing transfers (Except for the 3CX Call Control API). However, 3CX has announced a new REST API which is expected later this year. We do not have any information about what will be possible with this new API, but I am hopeful that it will include one or more transfer APIs. In the meantime, if you need a solution now, you can take a look at our VoIPTools REST API. We have several different transfer APIs for 3CX.
WagnerFT
