Auto Cab
Billy Wright
Hi as anyone got a 3cx installed working with software called "Autocab booking system"
Many thanks
Hi Billy
Try searching the forum for autocab.
Another user tried in the past but it appears they did not support integration at the time. Not sure if this changed now, but if they have a REST API it may be doable using our tool https://www.3cx.com/docs/crm-integration/
You may have to speak to the people at Autocab first to see if they support REST API
Senergia
