Automatic export from extension.csv
LeCroc
Forum User
Hello there,
i am looking for a possibility to export the extensions.csv (where i can create manually in extensions -> export)
aumatically.
I want that list to compare the extensions with the entries in our AD.
Is this possible?
I would use the Call Control API to gain access to the extension objects. You can easily create a list on a scheduled basis and perform the necessary comparisons.
Zexus
