Avaya (Nortel) 1100-series SIP phone unregister issue.
Well, I was hoping to be able to deploy the REG_REFRESH_INTERVAL change without having to reboot each phone.... but, no, even when the daily TFTP update occurs and the new REG_REFRESH_INTERVAL is read in, the registrations continue with Expires set to the REG_REFRESH_INTERVAL loaded upon bootup.....
Ok, here's the latest on this effort from here.
I've been able to get a relatively good (well, livable at least) result by using the following values:
In the 3CX System/Security/Anti-hacking setup:
1.) "Failed Challenge Requests (407)" is set to 28. (times)
2.) "Blacklist time interval" is set to 180. (seconds)
Everything else is default.
In the 1120E config:
REG_REFRESH_INTERVAL 1500
REGISTER_RETRY_TIME 30
REGISTER_RETRY_MAXTIME 1800
SIP_PING YES
Here's the timing, as listed in the server activity log:
Code:
11-Jan-2014 15:08:45.089   [CM504001]: Endpoint Extn:851: new contact is registered. Contact(s): [sip:[email protected]:5061 / 851]
11-Jan-2014 15:06:06.852   [IPBL] Packet from banned IP/range: ip = 192.168.1.117; Comment: PBX: blocked for too many failed authentications
11-Jan-2014 15:05:06.753   Blacklisted (Too many failed auth)
IP = 192.168.1.117; Failed auth: 0; unauth: 0; auth: 0; 407: 28
11-Jan-2014 15:01:21.053   [CM504002]: Endpoint Extn:851: a contact is unregistered. Contact(s): []
11-Jan-2014 14:36:03.820   [CM504001]: Endpoint Extn:851: new contact is registered. Contact(s): [sip:[email protected]:5060 / 851]
So the endpoint hangs unregistered for seven minutes. I can live with that, but would like to see fixed firmware.....
A packet capture of the port to which ext 851 is connected shows that, after the successful registration at 15:08:45 the phone re-registers properly, with Expires set to 1500, at consistent 1470 second intervals, from then on. The trick is getting the first failover to occur quickly enough, but not to timeout the blacklist too quickly (I tried first with 120 seconds, but that didn't work, and settled on 180 seconds, which seems reliable).
So there is a workaround, even though it is a bit of a kludge.
Just upgraded to 3CX V12SP3.
The 1120E behavior is the same as with V11. FWIW.
Well, through the 12.0 series up through 12.0SP6.1 the Avaya 1120E phones worked the same way as always, and were reliable when they stayed registered.
Upgraded to V14 this week, up through SP3, and now the phones are getting unregistered and reregistered roughly every thirty minutes. While I know the 1120E and kind aren't officially supported, to have something that worked stop working is more than a bit annoying, especially after just paying the annual maintenance renewal.
Reactions: icns01
Iowen,
You really have contributed an outstanding body of work here wrt trying to get the Avaya 1120Es working.
A real demonstration of tenacity and technical acumen....
Thank you very much, you have no idea how much you have helped myself and others, who have been trying to do the very same thing...get one of the most popular legacy IP phone series: the 1100 series (Nortel as so huge) working with the 3CX.
After spending considerable time troubleshooting this de-registration issue (including even a call to 3cx tech support on the registration timers) I was about to do the very same thing by sniffing the registration traffic between the 1120 and the 3CX when I came upon your (very instructive and detailed) thread. Again, brilliant work on your part and very nice of you to share with the community.
Yes it is indeed a terrible shame that an upgrade broke your work around.
Seeing that we are now at release 15.5 (we are running the Linus version) can you post an update on your experience since your last post in 2016?
Thanks again much.
Brian D. Browne
DejanMDS
