Solved AWS EC2 PBX Express Heads Up (V18)
brenulti
Gold Partner
Just tried to deploy a new instance after updating most of our clients tonight to V18.
We were getting errors at the select machine type menu. Took me a few to figure out but thought others may run into this
Do your self a favour and add Debian 10 to your AWS marketplace!
@brenulti Marketplace takes a few days to be updated on Marketplaces as there is a procedure on the background in order the images to be validated from each hosting provider until they are publicly released.
What is the error you got for the machine type ? Can you paste here a screenshot ?
"No machine types available for your account in the selected region. Try another region or open cloud provider portal and check that you can create machines in the selected region."
The resolution was to add Debian 10 to our subscriptions. Just figured a few other people may hit this as well,
you are right, the config guide will be updated today to reflect this!
Gotcha! I figured as much
GP Concepts
